Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1500 Perguntas Visualizar todos
Pergunta encerrada
replace home button?
Hi
Home Button crashes after opening the device I discovered that one of the pieces had been broken gold medals
I bought a new home button is clearly in the picture
http://www.traderscity.com/board/userpix...
I would like to know how to remove the old button and install the new
thank you .
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
It's easier to just solder the pin back on.
I've had several of these home button failures brought into my store and just put a slight dab of solder onto the connector from where it came. It's a very simply circuit and I've had 100% success with this method.
Make sure its bent up slightly to allow the pressure to connect onto the dock flex cable the activates the home button response.
Otherwise you have to fully disassemble the lcd, and heatgun remove the front panel/glass-digitizer and peal out the home button.
Esta resposta foi útil?
Pontuação 0
1 comentário:
thank you
Do you mean that i must remove the digitizer
What is the next step
Note that I want to replace the piece shown in the picture only
por
I mean that you dont have to remove anything, you can put a dab of solder onto the flex cable and affix the pin back on.
Otherwise you will have to heat gun off the digitizer/front glass to remove the home button which could lead to broken glass, torn flex cables, etc..
Pontuação 0
1 comentário:
thank you
I have tried to put the dab of solder but to no avail
And there is no solution unless we replace the flex cables I'm sure this
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 7,260
