Ir para o conteúdo principal
5th generation Apple router released on June 21, 2011. It features wireless n which increases the network speed from the previous model.
13 Perguntas Visualizar todos
Pergunta encerrada
Can A1408 extreme become a Time capsule?
hi, was wondering, is there a room for HDD inside it and is there a sata connection available on the board to hook up the HDD??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
no there is no hdd in there. for a time capsule the hard drive might die after a long period of time. if you want to preserve data for long periods of time you best bet is to copy your data into an SD card and vacuum seal it so nothing gets in.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Not sure if i understood you, yes i know there is no hdd inextreme, but i wondered can i fit one in, since time capsule is same dimmensios as extreme (i think it is)
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 516
