Ir para o conteúdo principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Is it my fuse?
My dryer stopped working mid-load. I let it cool off for 15 minutes and tried again. It started and continued drying the load.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Once a fuse blows it has to be replaced. Did this just happen once, are you getting any error codes, any power outages, what kind of main breakers do you have?
Esta resposta foi útil?
Pontuação 1
Run self diagnostic by and while in stand by press less heat, more heat, less heat more heat in sequence with in 5 seconds and then read code for problem possible. This link will further explain what you will find,
https://www.youtube.com/watch?v=7KaMwV85...
Pontuação 0
Adicionar a sua resposta
Kate Shaw será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 376
