Ir para o conteúdo principal
Sony Xperia Z3 Compact released in Sep. 2014.
82 Perguntas Visualizar todos
Pergunta encerrada
My Primary call mic is not working
Hi,
The Mic on my z3c is not working. I did a factory restore, even did the diagnostic and no cookie.
I disabled ok google and all that jazz. The phone is under warranty but the service center guys are refusing to consider it as the back panel is damaged and plan on charging me for the back panel and mic replacement which is completely unfair as the two had nothing to do with each other.
What do I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You need to solder a new mic on the mainboard.
Esta resposta foi útil?
Pontuação 0
Did you ever try to open the back panel by yourself? If yes, they would consider that you have broken the phone and made the phone warranty void. Since the mic is soldering on the motherboard, and it is hard to replace by DIY repair work, it is better to ask for the professional for help.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 749
