How can I delete my text messages
I have two Sims and I try to delete messages and they won't delete
Esta é uma boa pergunta?
Hello tina rose,
Note: steps and options may depend on the currant Android version of your phone
Cheers!
Esta resposta foi útil?
Hi,
Which cell phone do you have? As different sets are having different process on same thing. Still you will try one thing i will suggest you-
just go to the message box and select the message you want to delete. May be when you touch the screen for select the message you want to delete, it shows a option "Delete Thread" or "delete". If it is then click on this option. Your message will be deleted. Otherwise please specify first, which cell phone you are using...
i am using blu energy x plus with straighttalk and that didn't work but thanks
I am using Tecno Spark. Pressing the delete option after highlighting the message, doesn't work. All other options that indicates "delete message" cannot delete the message (s).
I'm using a techno spark.....can't deleate messages
Simple really on the Doro … go to settings, select the delete option and it comes up with options to delete all inbox, outbox, sent and finally all messages. Choose which and press ok.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 8,420
