Ir para o conteúdo principal
Why is my drone not flying?
It starts but won't take off?
It just flips over on the wheels and by itself it just dosent go up?
Esta é uma boa pergunta?
Pontuação 13
8 comentários
Mine has the same issue, its like the propellers are revered. It wont take off, it will only only push downward into the ground, its unusable!
por
I have the same issue
por
same issue anyone know why?
por
me too it just spins backwards all by itself when you take it off on the weels for a few seconds and i think it has to do with balanced weight but at the moment im still trying to figure out whats wrong
por
por
Exibir mais 3 comentários
Adicionar um comentário
12 respostas
Pergunta mais útil
The proppellers are mounted in the wrong order. Switch left and right propellers front and back. Had the same problem. The drone was pushing down instead of moving up
http://blog.parrot.com/2014/07/24/how-to...
Esta resposta foi útil?
Pontuação 6
4 comentários:
Hi thanks God bless you it works i thought my new drone was spoilt i came here read your started my drone and it came i recommend this to everyone IT WORKS
por
hello, thank you your suggestion works
por
Thanks a ton! UDAMAN
por
Top man. It's working now :)
por
Two propellers angle up and two angle down. Align then in a cross cross pattern so:
front left angle up - front right angle down
back left angle down - back right angle up
Pontuação 4
3 comentários:
Thank you so much. This is exactly right!
por
OMG this was helpful!!! Thank you!!!
por
Thanks it works perfectly
por
Keep switching the propellers and trying it until you get the correct order
Pontuação 2
1 comentário:
ok thank you
por
But I figured it out one of your PROPELLERS might be WEAKER than the other ones allowing it to be UN-EVEN. For mines that's what it is but I might need to buy new propellers if you can do that
Pontuação 0
1 comentário:
i bought new propellers it still doesn't work
por
yes thats all it does and dont come off the grown just flips foward
Pontuação 0
My drone typhoon h is not responding to the monitor
Pontuação 0
My typhoon h drone camera is nor responding to the monitor
Pontuação 0
No.it goes on it's side. And doesn't fly. It's not mine. It's a friends drone I was using
Pontuação 0
The wings are rotating but it doesnt fly
Pontuação 0
I had the same problem. I had to put the propellers on again after a crash and I just installed them on the wrong motor. Once in the right position it works like it’s supposed to. Good Luck!
Pontuação 0
Check the direction of the props. They might have gotten reversed and the 2 same angle props go diagonally to each other
Pontuação 0
if you press the takeoff button then try lifting up it should work
Pontuação 0
1 comentário:
my parrot rolling spider never failed so theirs should be a priority
por
Adicionar a sua resposta
Isaac Papasidero será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 46
Duração total: 17,699
