Ir para o conteúdo principal
Repair guides and support for phones manufactured by Lenovo.
273 Perguntas Visualizar todos
screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
Esta é uma boa pergunta?
Pontuação 1
5 comentários
I have the same problem for a LG Stylo 3 that was stepped on.
por
did u fix it i got the same problem and same phone
por
por
no my phone fell on the groud
por
Does this drain my battery?
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
Esta resposta foi útil?
Pontuação 4
3 comentários:
very good answer and simple but very useful
por
This answer saved me.. thanks a lot
por
I dont have vr mode ,what to do,?
por
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
Pontuação 1
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
Pontuação 0
i fixed new combo on samsung j7 and everything show a double plz help me
Pontuação 0
1 comentário:
Mine is Samsung A03 it just started showing double letters and everything is just double both the time and everything..plz I need help
por
Adicionar a sua resposta
Dragneel Potter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 73
Últimos 30 dias: 410
Duração total: 21,296
