Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
Pergunta encerrada
iMac will not power up led 501 is on
Due to my 2 year old boy taking my iphone 6 charger-plugged into imac and then putting the other end into an outlet my imac and most things connected to it have died.
I suspect the motherboard, but I am asking if anyone could confirm that via the last light being lit led 501 the one on the right. No change when i hit the power button.
Thanks for your help
Yes I spanked his little xxxx
Esta é uma boa pergunta?
Pontuação 0
13 comentários
Yes LCD is plugged in and Ram is still installed
por
That last LED light is sensing whether or not the LCD is sending/receiving a signal from the LCD. This would lead me to believe that either the LCD itself is out OR the graphics card isn't seeing it for some other reason. Do you get a boot chime?
por
I do not get a boot chime
por
Do you hear the HD spin up the OD checking for discs? Any fans spin up?
por
Nothing spins at all no sound at all
por
Exibir mais 8 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Okay, it sounds like the power supply itself has gone out, I'm assuming the 12v rail and maybe a few others. You might want to consider pulling out the logic board and having a good look at the capacitors to see if any are popped, or bulging (They should look like little pop cans that are flat on the top).
Also inspect the board for any scorch marks around components.
If you're interested in attempting to replace it the Power supply ifix it carries the part: iMac Intel 21.5" (Late 2009-Mid 2011) Power Supply
And you'll want to follow this guide:iMac Intel 21.5" EMC 2428 Power Supply Replacement
Gotta love kids! :P
Imagem de iMac Intel 21.5" (Late 2009-Mid 2011) Power Supply
Produto
$69.99
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 1,255
