Ir para o conteúdo principal
The Nokia N70 It is equipped with a 2 megapixel camera with built-in flash, a front VGA camera to allow video calling, FM radio, and Bluetooth.
9 Perguntas Visualizar todos
My n 70 nokia phone signal is not working
my n 70 nokia phone signal is not working
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
Please try the following ways.
1) Go to settings --> network and select manual option and see if its showing any other networks. If you can find your network just select it and you will be connected.
2) if not you can try to remove the sim wipe it and put it back again see it works.
if it still doesn't work, you can contact your telecommunication service provider. They will help you.
Regards
Abdul
Esta resposta foi útil?
Pontuação 2
1 comentário:
simcard not valid
por
Please make sure your carrier supports this phone.
The Nokia N70 only supports
2g 900, 1800, 1900 MHz
3g 2100 MHz
Pontuação 0
Adicionar a sua resposta
JIN P L será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 729
