Touch not working after replacing screen
I replaced the digitizer only an iPad 3rd generation. I haven't sealed it. It does come on and Siri comes on but the touch isn't working. Help!
Esta é uma boa pergunta?
If possible, remove the new digitizer, and test the old digitizer to make sure it's not an issue with the iPad's logic board.
If the old one works, you'll know you need to replace the new digitizer as it would likely be defective.
Esta resposta foi útil?
I can't put the old one back on because it shattered.
I should say I shattered it when I took it off. it only had a crack prior to my replacing it :(
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 132
