Ir para o conteúdo principal
Encontre soluções para as questões de reparo do seu computador.
21258 Perguntas Visualizar todos
Pergunta encerrada
Having trouble with video on new build
I've just finished building my first computer and am having an issue with the video card . The computer just sees it as a random generic card it doesn't identify the card in the device manager. What am I doing wrong?
ASUS M5A99X EVO motherboard
GeForce GTX 750 Ti SC 2GB GDDR5 video card
Im also having trouble with the LAN
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Have you loaded all the drivers and updated the drivers for motherboard. Motherboard comes with a drivers disk and will need to be loaded after you install your OS. By the way what OS did you install. But what you discribe sounds a lot like drivers not installed yet
Esta resposta foi útil?
Pontuação 2
3 comentários:
It did come with a disk but i didn't put a optical drive in so couldn't run the disk
por
you can go to the asus site and download the driver package for the motherboard then put them on a jump stick and install them . Do the same with the video card as you'll need the control center to get the most out of the video card
por
Thanks that did the trick. I guess it would have been worth my while to have put a dvd player in it
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 48
