Ir para o conteúdo principal
Um console chamado Nintendo Entertainment System lançado nos Estados Unidos em 1985 pela Nintendo. (Modelo NES-001)
No Image on TV and blinking light
Hi there! I bought a NES that doesnt work.. When i plug her on the TV, the light start blinking and no image appears on the TV, the image is the same as i didint have plugged the console.
Do you know what is wrong with the console? I tried different TV outputs and cleaning the cartridge reader.
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Best bet is to take the NES Console apart, neatly and replace the 72-Pin connector. This will solve the problem 99.99% of the time.
Esta resposta foi útil?
Pontuação 0
Hello. You have what may be a broken 72 Pin Connector. You May want to get a new one or it may be dirty so just clean it. The Game may be dirty too. Cut off the green part of a sponge or get scrub pads from the store too clean your pins. If it does not work, Open your cartridge and clean the pins well with a small ammount of counter top cleaner. brish it on and then take a towl and wipe the cleaner off. Then put the case back on. Please only do this with the game.
Pontuação 0
Adicionar a sua resposta
Daniel Reis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 1,345
