Ir para o conteúdo principal
A collection of guides and support to help with washer repair.
3478 Perguntas Visualizar todos
Machine not working , Error dE
Although the lid is closed and the magnet attached to the lid is intact, the door open error message (dE) is displayed and the machine (LG fuzzy logic model no. T6515TDPT01) stops working after taking two /three turns in wash mode. I seek help from you guys to fix the problem. Thanks
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Check to make sure that the connector coming from the switch is properly seated on the circuit board.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Might be the magnet, usually the magnet pushes this switch the shows the door is closed. Hard to explain. Do you happen to have pictures?
Esta resposta foi útil?
Pontuação 1
1 comentário:
I shall fix a stronger magnet and shall see if it works.
por
Power off the machine and unplug it if you receive the error mid-cycle or at the end of the cycle. After five minutes, restart the machine and try to open the door again.
Wait about a minute for the door to unlock if you paused the machine during a cycle. In this situation, the locked door and appearance of the DE error is merely a safety precaution.
Pontuação 1
3 comentários:
Simple and great solution!
por
I could not get you dear gillrois. plz explain elaborately.
por
Click on the link for troubleshooting LG washer with error code DE. Hope this help Immi.
http://www.ehow.com/how_7850983_troubles...
por
Adicionar a sua resposta
Immi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 245
