Ir para o conteúdo principal
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 Perguntas Visualizar todos
After replacing motherboard touch screen not working
After replacing the motherboard touch screen won't work with fingers and sometimes will work with s-pen but not accurate and can't really work with it, why this is happening?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
When I replaced motherboards of my it doesn't work properly what can do
por
Try and see if the cable is connected tight enough, otherwise please be more specific.
por
Adicionar um comentário
2 respostas
I didn't connect the cables of the Spen and the touch tight enough, everything works perfectly! was very easy to replace the broken motherboard, Thank you iFixit for fast shipping!
Esta resposta foi útil?
Pontuação 0
The digitaliser black ribbon should to be pushed in properly otherwise only s pen works and the touch will not
Pontuação 0
Adicionar a sua resposta
DocBrown será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 890
