Ir para o conteúdo principal
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100 Perguntas Visualizar todos
whites become bright pink for a long time
For no apparent reason the whites in my tab S screen became bright pink. I tried everything... even factory reset with no result. Left it with no use for varios days and when I turned it on it was working fine for a while...then it turned pink again. It has done that a couple of times. The tablet has never fallen or gotten wet or anything. Always in a protective keyboard case.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
if your tab uses LCDs and not LEDs for back lighting, its a sign that the bulb is dying
Esta resposta foi útil?
Pontuação 0
Thanks for your reply. I have no idea if it's one way or the other... Can it be fixed?
Pontuação 0
It does that whenever a strong 4G network is available. Its a good sign that your internet around is very strong
Pontuação 0
Adicionar a sua resposta
Pato Duque será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 90
