Ir para o conteúdo principal
Pergunta encerrada
From where will I get the antenna connector cable for the phone
Hello,
I am in the process of replacing the charging port connector flex and have run into a problem. The antenna connector located near the battery is damaged and I would like to replace it but couldn't find it anywhere in the site? From where can I get it?
For the 6 it comes with the flex. In the case of 6 Plus it is a stand alone part plus it is crimped on both the ends.
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
This should help
iPhone 6 Plus 5GHz Wi-Fi Antenna Replacement
You can buy it here
Imagem de iPhone 6 Plus 5GHz Wi-Fi Antenna
Produto
$7.99
Esta resposta foi útil?
Pontuação 6
Amazon is another source for iphone parts
Tear it down with this
Pontuação 2
EbayAntenna-Connecting-Connector-Flex-Cable
Pontuação 1
1 comentário:
They sell them on Ebay
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 98
