Ir para o conteúdo principal
Why won't my Nano turn on?
I have plugged it in,can't turn on ,what do I do?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
Check out the Nano 3rd Gen troubleshooting guide. It has the order of testing you should follow.
Good luck!
Esta resposta foi útil?
Pontuação 1
my ipod fell out a car now its not working
Pontuação 0
1 comentário:
brennen roulette, it is a lot easier to get any help if you ask your own question. On the right hand side on this page you find a link "Ask a Question" and if you click on it you can give all your information and give a concise description of what device you have and what happened to it. Right now your question shows up as an answer to an old question and not to many people that could help you will see it. So if you expect some help, please ask you own question as described. Good Luck
por
I have had this. It usually can be solved by plugging it into a PSU and letting it charge from there.
Pontuação 0
Adicionar a sua resposta
mike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 8,493
