Why do I hear static noise when I plug in my headphones?
When I plug in my headphones to listen to music, all I hear is static noise. I have tried adjusting the volume settings and nothing worked. Help me?
Esta é uma boa pergunta?
First check if the headphones are plugged in properly. If you continue to hear the static test your headphones with a different device. Finally if you still hear static there could be a problem with your audio jack. Refer to the Nokia Lumia 520 Troubleshooting to fix the problem.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,166
