Why is my computer not holding a charge?
My computer won't work unless it is connected to the charger. If it is off the charger, the computer will not power up.
Esta é uma boa pergunta?
It may be time to change batteries. or the power input port may be partially broken to not letting the battery charge. HP are easy to change as they are usually a plug in on the motherboard and not solder on . Hope this helps
Esta resposta foi útil?
The battery may be a faulty one if it is unable to retain a charge. If there is an issue with the battery then you should replace it.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 230
