Ir para o conteúdo principal
Uma calculadora gráfica popular lançada pela Texas Instruments em 1996.
How to remove back cover?
I have a TI-83 graph calculator (not TI-83 plus), I think, by (c), it's from year 1996.
On the back cover I only see two screw (not 6 as I see here in another teardown). I have remove that 2 screw but can not remove the cover. How can I release the back cover, without broken it ? Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
At the bottom, by the data port, you can get a small screwdriver or plastic tool in the seam on both sides. Then just cautiously work your way around and toward the top; there are some snaps which will come loose.
I had the same issue with mine and got so frustrated that I just didn't care anymore if I broke it! It turns out that was the way to go.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
luisfiliperibeiro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 4,798
