Ir para o conteúdo principal
O TDK Trek Max é um alto-falante portátil sem fio com recursos Bluetooth. O microfone integrado permite funções de viva-voz para qualquer dispositivo pareado ao alto-falante via Bluetooth ou conectado a ele. As portas auxiliar e USB tornam o alto-falante compatível com quase todos os dispositivos.
Why won't my speaker turn on?
I have had the device plugged in all day and it still won't turn on. My brother has the same speaker and uses my charger so I know that is not the problem. I'm thinking the battery is dead or maybe the charge port is malfunctioning. What can I do?
Esta é uma boa pergunta?
Pontuação 4
1 comentário
I saw you mentioned the sound was low on this speaker in another thread, did you get the power issue resolved then?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
If the speaker is not turning on after a full charge it could be suffering from a battery malfunction. Follow our guide on battery replacement to fix this issue.
Esta resposta foi útil?
Pontuação 1
Trek max will work even without a battery connected. (power supply must be connected). I have one that works only when fully charged for a short time unless charger plugged in. This indicates a problem with battery voltage sensor. Same battery works fine in another unit. Your problem may be a worse case of this. I suggest Remove battery and test it.
Pontuação 0
1 comentário:
My Trek Max A34 will not charge. I thought it was the battery so I boughf a new one. That won’t charge either. Only way Trek Max will work is plugged in. How do I fix this issue?
por
Jag får inget ljud i högtalarna
Pontuação 0
Adicionar a sua resposta
Rebecca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Ao todo: 4,320
