Ir para o conteúdo principal
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
20 Perguntas Visualizar todos
Why can't I install the usb driver?
After installing windows 10 there were a couple missing drivers. I troubleshooted the laptop in devices and printers and it fixed all the driver issues except for the USB2.0-CWR driver. It says it doesn't have it. I tried to update it from device manager but it says windows can't find the driver, go to the manufacturersame website. I couldn't find it on dell.com either. What should I do?
It says in properties that the drivers for this device are not installed. (Code 28)
Esta é uma boa pergunta?
Pontuação 0
3 comentários
have you updated windows 10 yet it could help
por
I'll try that thanx.
por
Ran a bunch of updates. Didn't change it. I had a problem on an hp pavilion recently where it didn't recognize the DVD drive. It seemed like a driver problem but was actually something in the registry that needed deleted and then it worked fine. Could this be something similar?
por
Adicionar um comentário
4 respostas
Solução escolhida
Hi,
Did you try this link, scroll to bottom and download Realtek USB 2.0 card reader?
http://www.driverscape.com/manufacturers.... If you have please ignore.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks, Jayeff, your link worked great.
por
down load driver genius it should find the driver.
Pontuação 0
Hey! It is easy! If you can't download drivers from official website, you can try to use a 3rd-party driver program to download driver for Windows 10. More detail: http://goo.gl/5h6ICN
Pontuação 0
maybe you should look for the driver Sesua, try visiting http://www.aiydriver.com and find your laptop drivers
Pontuação 0
Adicionar a sua resposta
Jesse será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 1,585
