Ir para o conteúdo principal
Guides and repair information for the Lenovo Thinkpad T430, a 14-inch business laptop by Lenovo.
28 Perguntas Visualizar todos
Power button LED Blinks when I press power button.
Lenovo T430. Tried following steps, No luck. Refer to my Video here.
  • Try charging the Battery to Full
  • Remove Battery and tried booting it with Power directly.
  • Changed the Keyboard.
  • Removed the Bios Battery and tried to switch on.
  • Removed the RAM and tried to switch On.
Esta é uma boa pergunta?
Pontuação 2
6 comentários
Is there a pattern to the blinking?
por
No It just lits up and turns off. I dont think it is a pattern.
por
is there one or two sticks of ram
por
Do you get any fan sounds? Do you hear the hard drive spin up at all
por
yes i hear a fan sound, it comes and goes off (the sound)
por
Exibir mais 1 comentário
Adicionar um comentário
2 respostas
Solução escolhida
Try removing one stick of ram if you have two and test one stick at a time in each of the two ram slots. Then test the second stick of ram in both ram slots this will tell you if you have bad ram or a bad ram slot. if it still doesn't work you need to consider getting out a multi meter and tearing open your computer and testing the circuit board starting at the power outlet and working into the board
Esta resposta foi útil?
Pontuação 3
2 comentários:
I tried the RAM swaps , no change. Also Fan wont turn on. I am not familiar with electronic circuits.
por
Even now 2021 i have that problem on my Lenovo All-in-One Computer IdeaCentre 300-23ISU (F0BY0041US) Intel Core i3 6th Gen 6100U (2.30 GHz) 8 GB DDR4 1 TB HDD 23" Touchscreen Windows 10 PRO 64-Bit
por
I have a T430 with the same issue. LEDs (power Fn F3 ) are blinks one but the laptop does not turn on.
I triedtoclean the connections, remove the batteries....no change.
Once i removed the RAM and the unit booted up.
So the issue is the following : it works with no RAM, but it does not work with installed RAM.
The problem is the same with the old and a brand new RAM also.
Any idea?
Pontuação 0
Adicionar a sua resposta
ksenthilbeit será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 43
Duração total: 30,521
