Ir para o conteúdo principal
How can I fix sunken volume button?
My iPhone 6 volume button is working but is sunken and kinda loose. I opened the my iPhone to try to if I was able to notice what was the problem but I'm no technician so I had no luck.
Anyone knows how to fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
You will need to open the phone and verify which is the broken part.
This guide can help you with that.
iPhone 6 Volume Control Cable Replacement
If you don't feel comfortable to open your phone yourself, you should find a repair shop near you.
Esta resposta foi útil?
Pontuação 0
usually that screw will come loose or will back out on it own. Simply open it up and tighten or stop in to a local apple store and have them take a look at it. Should be a quick fix.
Pontuação 0
Adicionar a sua resposta
darodriguez9092 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 17
Duração total: 24,450
