Ir para o conteúdo principal
Repair guides for Android cell phones manufactured by ZTE.
1282 Perguntas Visualizar todos
How do you fix my launcher when its stopped?
My Launcher On My Phone Has Stopped & Im Scared My Phone May Be Completely Broken ANY HELP
Esta é uma boa pergunta?
Pontuação 11
2 comentários
Were are the answers
por
I don't have a phone. It is a Chromebook
por
Adicionar um comentário
8 respostas
Pergunta mais útil
If this happens often it maybe time for a new launcher. I find the Google Now launcher really nice. You can download it from the google play store and when installed, press the home button and it will have a pop up message, select Google Now launcher and click for it to always do this. Finally, just rearrange your icons and your good.
This works on almost all launchers and some are better than others, I like google now but there are others like GO! launcher and more.
Esta resposta foi útil?
Pontuação 6
1 comentário:
I know this comment is from 2015 but I just had this launcher problem and all if good in my world now because if your solution. Thank you so much!
por
Turn off phone & restart.
Pontuação 1
2 comentários:
What to do when ZTE only shows launcher 3 has stopped and then not even a second later the phone turns off I can't get into any of the system settings two clear the data or the Play Store to download a new launcher what do I do
por
Powering down only works temporarily. Been fighting with this BS for over a year! ZTE is a joke in my eyes!!
por
Buy a new phone.
Try to take batteries out of phone let it sit for a few min then try to restart phone. Also try to set phone back to factory setting.
Pontuação 1
I had the same problem 2 weeks after i got my ZTE piece of crap phone. I hate this phone. I read online from someone that they had the launcher problem also so i was prepared and as soon as it went down i swapped it out for a launcher from Google PlayStore. Its called ZenUI Launcher its 45mbs and has worked perfect but there are so many to pick from just take your time and read the reviews. Hope that helps.
Pontuação 0
2 comentários:
I am right there with you! This is the WORST phone I've ever had! I have 1 that are POS's! 2 different models! So it's not just a specific model! Its ZTE period!!!! Won't even allow an update to 5.0 or any other! You're stuck with 4.4 if that's what yours is running on!!
por
Correction I have 2.
Should have proof read before posting!
por
Same issue, just completely shut down can't take battery out so no Google anything, am I screwed?
Pontuação 0
If your Android pops a notice "unfortunately launcher has stopped working* and you push OK but the notice has frozen your phone or tablet you may be hacked, infected with a virus or something other than the real App? Because every other notice that stops working, when you hit OK it leaves the screen for awhile so you can go into your settings? There's still another way, if you press your up volume and on/off button at the same time a a sub screen comes up ( my Alcatel 4.4 is blue and mine wouldn't work, but this helps a lot of users). Once it comes up use the volume keys to navigate or scroll to get into settings. You are going to have to factory reset your phone. I have done this before and never ran a backup with my Google acct. and they saved everything anyway. If you can't get that sub screen? Try navigating around the notice while tapping the OK key. That's how I finally got into my settings. Just because you downloaded an App from the Google Play Store, dies not make it safe from malware, Adware or spyware. And FYI Google changed the OPT out AD version to accept ads so we can get free Apps. They are embedded in the Apps? The Ads are set to our browsing preferences and history. My phone didn't come with any security just remember your phone is 10x's more vulnerable than your computer!
Pontuação 0
How can I fix my launcher?
Pontuação 0
Pontuação 0
Adicionar a sua resposta
briannacarter50 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 12,083
