Why is my laptop overheating?
Whenever my laptop is being used for a long period of time the bottom begins to get really hot. Is there any way that this can be fixed?
Esta é uma boa pergunta?
This is a pretty vague, general question, since there are dozens of reasons why a laptop gets hot.
Through normal usage, though, the laptop internals (CPU, GPU, RAM, etc) will get hot from being used for a while. Whatever your system uses to regulate fan speed (if there is any active cooling inside) probably keeps your laptop operating at a set temperature deemed safe.
You may want to keep the ventilation holes free from any obstructions, like dust and other objects sitting in front of it. This will allow the heat building up inside to properly exhaust.
Esta resposta foi útil?
It truly depends you can try adding a stand to ventilate it or run a cooling system test
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 6,348
