Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
Pergunta encerrada
new hard drive installed
I have installed a new hard drive in my mac book pro 13" A1278, but can not get the Snow leopard disc to load. All I get is a beeping alert and the blue light on front right corner flashing.
Update (11/19/2015)
I am not all that clued up on trouble shooting with computers. but when I put the new hard drive that blank how do I connect to the internet. when I turn on there is an apple sign with a question mark on it.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Base OS: OS-X 10.6.6) Snow Leopard {10J3210} From EveryMac: This system fully supports the last version of OS X 10.8 "Mountain Lion" as well as OS X 10.9 "Mavericks" with the exception of the "Power Nap" feature. It also supports the last version of OS X 10.10 "Yosemite" and current version of OS X 10.11 "El Capitan" -- including Mac-to-Mac AirDrop and AirPlay Mirroring capability -- but other advanced features are not supported.
por
Can you describe the beeps (number and if they have a pattern). Also what drive did you put in make & model.
por
I had put a Toshiba Disk drive MQ01ABF032, 320 GB 5400 RPM 2.5" and the beeps are 1 sec apart.
por
When I insert the disc Snow Leopard I get a series of three beeps. How do I get the disc to start loading. It is a new hard drive that I have installed.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Do a web install. With a new hard drive you can connect to the web (I prefer a hard wired connection for this but Wi_Fi will work. You should be able to just boot it up and after it can't find a system if will ask for your router password. Disk Utilities will down load. Format the drive and then do a system restore. The original system will install then you can set it up and do your upgrades via the APP Store.
UPDATE 11/26/15
The tree beeps are a RAM error. Try resetting g then RAM, one at a time in each slot to test both the `RAM and the slots. Have you changed it?
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 326
