Ir para o conteúdo principal
The Canon EOS Rebel T3 is a continuation of Canon's entry-level line of DSLR cameras, the Rebel series. Also known as the EOS 1100D and the EOS Kiss X50, it features a 12.2MP sensor and a DIGIC 4 image processor.
replacing main board after water damage
water bottle in backpack broke and camera got soaked. Dried it out, worked o.k. for about 2 years but now it is focus hunting and won't shutter. Had it looked at by repair shop, said main board needed replacement. Wanted over $200., I only paid $300 for camera. Wondering if I can replace the main board without too much trouble and where I can get a board and approx. cost.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
take out the bottom screws, take off the hot shoe and lens and sensor then soak the main board in water and take a brush and put some denatured alchihol on it and scrub the board then dry and reassemble
Esta resposta foi útil?
Pontuação 1
1 comentário:
Also note if you do use water to clean the main board, it should be using either distilled or deionized water.
por
A bit late of an answer, but it is definitely feasible to replace the main board, though it does require a decent bit of disassembly to be able to access the main board. You'd have to remove the back, front, and top covers to be able to get at it. This guide will take you through all of the steps necessary to replace the board.
As to finding a replacement, you can just search up "Canon Rebel T3 main PCB board" to find sites that sell them. eBay is one place that you'll likely find it being sold at, and probably one of the cheaper places you can get one from since you can find used boards being sold there. You can also try searching for it using its part number, which is "CG2-2977".
As for the price, at the time of writing this answer it seems like you can find places that sell them for around $100-$150. I also did find a used board being sold on eBay for $65
Pontuação 1
Adicionar a sua resposta
Marjorie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,666
