Ir para o conteúdo principal
Pergunta encerrada
iPhone 5 problem with brightness
Hi,
I buy Iphone 5 and I have problem with it. Everything is good but my screen is dim. So my screen is working, touch is wokrikng everything is good, but brightness work for just 30% :( I slide manualy settings for brightness on full and brightness is stil just maybe 30% from 100% :( I try change my display with new proximity sensor and do nothing :( any sollution please ? Thank you very much :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This might not fix it, but in your shoes I would try a "force restart". With the phone on, hold down the home button and the power button until the phone shuts off, and turn it back on.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hi
Thank you for soluion but I try it like first and do nothing :( any another solution? I am little good repairman in iphone but I think it is mistake on mainboard and I thought someone on this website have some problem like I :)
por
I know it sounds silly, but same thing happened to me. After much research, and all kinds of resets, hard resets, etc..., someone suggested deleting as much data from phone as possible, then restart. So I deleted as many apps as possible. Strange, I know, but it worked! Good luck!
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 92
