Charging Problem iPhone 6
I have an iPhone 6 that has a charging problem: if I replace the battery with a charged one, it works until it becomes discharged, then the battery can not charge again.
Esta é uma boa pergunta?
It's U2 Tristar charging ic at fault as it refuses to let a flat battery charge.
Esta resposta foi útil?
Thanks, how can i fix it? anywhere i can send to fix it?
Yes. You will need to look for someone that does board level micro soldering for iPhones.
Is there any resolution to this isssue? i have the same issue!
Replace the charging flex cable.
If it charges while not dead, how is it this?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 191
