Ir para o conteúdo principal
The Sprout Channel Cubby™ was first produced in 2014, it is a child friendly device that provides the functionality of a tablet. It boasts a 1024x600 touch screen, Two 2 megapixel cameras (one rear facing and one front facing), Parental controls and security, HDMI connectivity, Bluetooth, WiFi, 16GB Memory, 1GB RAM, and a 1.2 Ghz processor. It has access to internet and various application stores and applications, which can be limited by the parental controls
Why wont my device charge when plugged in?
when i plug in my device it does not charge why is this?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
4 respostas
Pergunta mais útil
My device want charge at all or it want come on at all need help please......
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hello,
I am getting nothing when trying to charge my cubby. The device won't even turn on. Thanks Jeffrey_Hemingway@yahoo,com
por
It is possible that you don't have the adapter fully in the charging port or it is possible your charging port may need replacement. Before attempting to replace your charging port check to see if the cable & adapter will charge another device it is possible it is a faulty cord or adapter
Pontuação 0
I found a battery wire that is soldered to one of the three pads on the main board was not connected they felt tight but were being held in place by the plastic insulation. I stripped back the insulation(about 1/16 inch) and resoldered the connection
Pontuação 0
maybe its your cable not working probably, i suggest you get a new one. I reckon it won't be too pricy
Pontuação 0
Adicionar a sua resposta
jasen biggins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 1,730
