Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Display assembly from a late 2013/2014 MacBook fit the early 2015?
Im looking for a display assembly for my early 2015 13 inch MBPR.
Some sellers claim late 2013 and 2014 fit the 2015, and some claim the opposite.
Any help is appreciated!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have a Early 2015 M/Pro and can verify the screen from a 2014 dose work. I had to install Mac OS connected to an external display
So thank you for all your comments
por
Adicionar um comentário
4 respostas
Solução escolhida
My magic eight ball gave these replies:
Don't count on it
My reply is no
My sources say no
Outlook not so good
Very doubtful
https://en.wikipedia.org/wiki/Magic_8-Ba...
The old screen may fit, but are the cables right?
Ask these guys when they will stock it: MacBook Pro 13" Retina (Early 2015) Display Assembly
Imagem de MacBook Pro 13" Retina (Early 2015) Display Assembly
Produto
$449.99
Esta resposta foi útil?
Pontuação 2
I was reading conflicting answers on whether or not the 2013/2014 display assembly would work on the Early 2015 MacBook Pro Retina. Despite the fact that that the earlier display has the same connectors, and runs at the same resolution, I got no video from the late 2013/mid 2014 display. Best to bite the bullet and order the early 2015 display assembly right out of the gate. I've wasted more money than necessary now shipping and repacking the 2013/2014 display assembly for a hopeful refund.
Pontuação 2
They will not always Sync up together.. Will work intermittently. Get the right year and model eben though everyhting plugs in correct you will have issues..
Pontuação 0
It will work. I’ve done it myself. The only issue is when it boots. You will have a black screen. This will stay on until the load bar reaches half way then it will boot up as normal and work. But. If you reload a new OS. YOU WILL STILL GET THE BLACK SCREEN DURING INSTALLATION. JUST USE A FLASH LIGHT AIMING ON THE SCREEN SO YOU CAN SEE THE PROMTS. This is the only issue I’ve encounter. It has to do with the backlight which lights up the Apple logo on the screens back side of the lid. I think it’s something to do with the EFI not picking it up on start up and when you use the computer on verbose mode. But like I said. Other than what I mentioned. It will work.
Pontuação 0
2 comentários:
Is this true? Can you provide any proof of answer? Only asking because I don’t want to break my 2013 MacBook Pro.
por
The bootup behavior described above is my experience as well. The screen will work after a delay of a few seconds. On things like target mode, diagnostic mode, and recovery mode, the screen won't work, but the computer is doing what it's supposed to do.
por
Adicionar a sua resposta
Christoffer Klein será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Duração total: 4,401
