Ir para o conteúdo principal
Repair guides and support for cars, trucks, and SUVs manufactured by GMC.
290 Perguntas Visualizar todos
oil leak towards front of engine
recently had oil change, going down road stop to fuel up check oil,to notice 2 qts. low, oil cap is tight,oil filter is tight, front of engineand all of under carrage is fuul of oil,only lower half of front of engine covered in clean oil...???
Esta é uma boa pergunta?
Pontuação 1
1 comentário
had a repair shop lift an observre my oil leak problem,they responded; to much oil on engine to see where it had come from,,possibility from front seal....
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Get a couple cans of engine degreaser and follow the directions to remove the oil from the engine (make sure you are parked somewhere that wont stain)! Refill the oil and start the engine while monitoring where it leaks from.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
timothymanie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 250
