Ir para o conteúdo principal
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Perguntas Visualizar todos
Pergunta encerrada
Digitizer Cable Keeps Discoloring LCD Screen
I work at a cell phone repair shop and I am new to iPad repairs but have been having trouble with the digitizer cable when closing down the iPad. I try to pre-bend it but it still seems to be hitting against the LCD and causing a slight discoloration (only when the screen is black and backlight is on) where the pressure is. If it is opened up again the discoloration goes away. Is there any tips or tricks to stop this from happening? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You need to order better digitizers i'm sure the one your using wont bend in the ipad case some digitizers comes with adhesive behind the middle of the flex take a look at steps 27 and 29 thats how it needs to be bend in order to prevent the flex pinching the lcd iPad 2 Wi-Fi EMC 2560 Front Panel Replacement i was looking at some videos so i can show you but none of them are showing the proper way to push the flex in all of them are just closing it. can you send a picture of the iPad flex.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 50
