Ir para o conteúdo principal
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
Esta é uma boa pergunta?
Pontuação 4
1 comentário
that fixed the problem. thanx.
por
Adicionar um comentário
6 respostas
Solução escolhida
Also, try visiting the troubleshooting page for more help.
Esta resposta foi útil?
Pontuação 6
Pergunta mais útil
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
Pontuação 18
12 comentários:
Worked for me, i feel so stupid now
por
Mine was not working either, Supid #2! Thanks!!!
por
Wow! Thanks! *face palm*
por
Add me to the dummy list! Thanks for the help
por
Not working. Howwwee
por
Exibir mais 7 comentários
Try resetting the watch.
Pontuação 3
3 comentários:
I reset it and it only vibrates on phone calls.
por
I reset mine nothing, no vibrating at all. I'll try again.
por
Though it works, feels over kill. Try the quiet mode
por
No solution worked. No vibration at all even after hard reset
Pontuação 1
My pebble steel started to vibrate again, after android wear app was removed
Pontuação 0
2 comentários:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
por
Thanks. I m on the top of the dummy list!!
por
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
Pontuação 0
Adicionar a sua resposta
Orlandria Heggs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 15,695
