Why doesn't the heater/ac and power windows work?
Whenever I start the car the power windows do not work and the heater/ac won't turn on as well. Sometimes they both run but most of the time they do not run. I have looked at the fuses and have not found any of them are bad. I am not sure where to look or what to do.
Esta é uma boa pergunta?
Pontuação
Do the power windows work when you turn the key to on but do not start the engine? Unlikely that it is a fuse since the error is intermittent. Besides the fuses, what else have you checked? Both of those accessories do have relays, so that is where I would start.
por oldturkey03
The windows do not work in accessory position. The only other thing that I tried is simulating starting the car while I was driving this started heater and windows, but it only worked once.
por ddeheine
