Ir para o conteúdo principal
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 Perguntas Visualizar todos
Pergunta encerrada
Why wont it charge unless I hold the cable
I have to hold my cable at the end connected to my ipod and push it so it will charge but that is a pain is there any other way to charge i have an appointment at the genius bar but i would still like to know
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Try cleaning the charge port out with a tooth brush and 99% alcohol. 9 times of out of 10 there is dirt or lint causing issues and much cheaper than a charge port replacement, always try the easy way first ;) If it still continues then you will need to seek a charge port replacement. Note that the charge port replacement on this model is not a easy repair it requires soldering and patience to not break the lcd coming out.
Esta resposta foi útil?
Pontuação 0
Its your charging port. I had the same prob and i opened it up and replaced it.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 103
