Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Can I reattach a severed Home button FLEX CABLE?
I inadvertently broke the flex cable of my home button while lifting up the screen.
I read that a replacement home button will NOT allow me to use Touch ID anymore.
Is it possible to repair, maybe solder the flex cable that I broke?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
It is impossible sadly. They are directly correlated with the logic board for security reasons and if you break one you're out of luck. You could try and find a new logic board with a home button but that might be costly.
Esta resposta foi útil?
Pontuação 0
It is possible, I've seen people do it.
Pontuação 0
Got the exact same problem, two different answers...
@Rocket Repair: so basically the cable itself is linked with the logic board and not the Touch ID sensor? That means hypothetically you could change the home button if you keep the original cable?
Pontuação 0
If it's just a broken flex cable then with a lot of patience they can be bridged with fine wire. It was done on a camcorder so maybe similar, see this video
https://youtu.be/FzqIoq8LEEc
Pontuação 0
Adicionar a sua resposta
Alex222 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 288
