Why is my charger for ipad 2 gets hot?
when charging ipad 2 charging adapter gets hot.
Esta é uma boa pergunta?
Chargers getting hot is normal because about 220 to 240 AC volts are converted in the charger to 5 DC volts. Chargers contain components like transformers, resistors and capacitors (among others) which gives off heat under normal load.
Charger getting hot should not be a problem unless it happens even when the device (iPad in this case) is not connected.
Esta resposta foi útil?
Connected to what? Mine is getting hot too. Is it a problem?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 11,530
