Ir para o conteúdo principal
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
Adapter failed. NO power.
Anything fixable in a MagSafe power adapter? Mine quit- no power, wires have no obvious breaks.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Check the pins in the tip with a tooth pick to make sure they are extending. Here's a video on how to repair them: http://www.youtube.com/watch?v=qd3RIV9sd...
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thanx. After my wife bought a new adapter (she is not a person who fixes anything), I did look at the computer end and discovered just what you suggest. Poked the little spring loaded contacts and they sprung like they are supposed to and all was well again. She now has a spare adapter.
por
Glad it worked for you. Sorry you jumped the gun and bought another one.
por
Adicionar a sua resposta
rwittig será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 3,544
