Ir para o conteúdo principal
Repair and disassembly guides for Asus tablets.
User interface won't display
Original Post: Asus MeMO Pad 8
The Asus MeMO Pad 8 (ME181C) tablet user interface has disappeared. The screen lights up but there is no display. It will not restart at all either. None of the soft or hard reset options have worked. I've also tried letting the battery drain completely so it would (hopefully) turn itself off to reboot. No joy there either.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
You can try and reflash your tablet sounds like something got corrupted
Below is a link that hopefully will give some info that may help you recover your tablet
http://forum.xda-developers.com/general/...
The following two links are from Asus regarding how to update firmware and also the firmware itself (I think)
http://www.asus.com/support/FAQ/1011948/
http://www.asus.com/us/Tablets/ASUS_MeMO...
If not happy to try above, check your warranty, if still valid contact the manufacturer.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Lydia Brown será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 150
