Ir para o conteúdo principal
Pergunta encerrada
display/phone dies when syncing or trying to backup
Whenever i try to update or backup the phone , it dies. see link to video below.
It doesn't matter if i backup using the lightning cable, or over WIFi.
I replaced the display since the glass was cracked. but I had the same problem before.
Interestingly I managed to download iOS 9 without a single reboot (which took more than an hour), but when i try to install it , the phone dies after some 15 sec.
the same happens when i try to backup the phone in itunes.
here's a video of what happens when i tried syncronizing if over WiFi:
https://www.youtube.com/watch?v=OWiIkuLX...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Uninstall ios 9 and power off for 3 minuts and repower. Then try to compleat your task with out ios 9.
Esta resposta foi útil?
Pontuação 0
1 comentário:
sry for not being precise enough. I downloaded iOS 9, but i haven't been able to install it. So the device is still running iOS 8.2. What worked was the download of the files for iOS 9(which took some hours).
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 42
