Ir para o conteúdo principal
The Huawei Mate 7 (also called the Huawei Ascend Mate 7) is an Android smartphone produced by Huawei, released in October 2014. Models MT7-TL00, MT7-L09, MT7-TL10, MT7-CL00.
21 Perguntas Visualizar todos
Why they can't hear me during a call
During a call, i can hear the person on the other line but they can't hear me. If i use the loud speaker mode or connect a head phone they will be able to hear me then. I already tried to restart the phone and even tried to reset it but still don't work. I wonder because I never dropped it and the phone is just a year old. So please help me. Thank you and I look forward to the help you can give.
Esta é uma boa pergunta?
Pontuação 10
14 comentários
I also have this problem
por
I also have the same problem
por
I also have this problem and phone has been back to repair centre twice but same problem again!!!!
por
I also have same problem
por
I’m having the same problem with my p smart
por
Exibir mais 9 comentários
Adicionar um comentário
5 respostas
Solução escolhida
Hi @ toni_alison,
Check the suggestions in the Chosen Solution in this link and see if they help, especially regarding the voice inlet hole being blocked
The information is relevant, except for the phone make and model of course ;-)
No One can Hear Me... HELP!?!?!!
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
My wife had this trubble, it was from a small amount of rain water that got into the microphone and killed it. The fix is to take the device apart, desoder the microphone, soder in a new microphone and put the device back to gather. HTC refused to honor the warenty then they voided the warenty wich forced me to fix it after they charged us $147.97 just for the microphone, the phone was only a $65 device. My advice, save the trubble, put it in the bone yard and enjoy a new device.
Pontuação 2
2 comentários:
Sounds to me like it's an internal mic problem
por
I found problem of mic
Go your phone's setting and go sound and search sound enhancement and turn off besloudness
Because I fix problem of my mobile to use it
por
hi. i had the same problem and got new phone because mine was under warranty. mine had the problem with the noise cancelation microphone which is near the headphone jack. The person on the other line could't hear me when i used the loud speaker mode, only in normal mode. So if you have warranty with your phone go with it and they will fix it or will replace it. Mine was replace it.
Pontuação 0
Is the phone under warranty? If so, you can take it to the service center of the manufacturer since Huawei puts much attention on product quality and customer's satisfaction.
Pontuação 0
My mobile is honor 10 lite
And I'm able to listen who called me
But they don't
What should I do
Pontuação 0
2 comentários:
use a headphone or earphone , your microphone could be the issue
por
@Famis Kadiro This is a wonderful suggestion....THANK YOU SO MUCH...Obviously my mic is playing up, but when I put my earphone in and phoned someone they could hear me. However, the recorder still isn't working, but I can cope with that as long as people can hear when I ring them..YO!!! thank you again.
por
Adicionar a sua resposta
Venus Gacad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 68
Duração total: 63,192
