Ir para o conteúdo principal
A new iteration of the set-top box, a side-set box. Chromecast connects to your Wi-Fi network to stream content from your compatible device to your television.
Why is the screen and audio not working?
My chrome cast stop working . It would be showing the light on the device but no image would appear. It would let me connect a video but it would not appear but it would say it is playing . Also on an other chrome cast it would flicker but show an image yet no audio could be heard.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I'm having this trouble too. Mine is the new 4K model, powered through a USB3 hub. I've tried 65w chargers, 5v 20w power supplies (constant voltage) with no luck.
Eliminating the USB hub doesn't seem to change anything.
TV will turn on and I can cast to it from my phone, but no signal.
Reseating the hdmi does nothing, not a flicker. Power cycling the device with the cable fixes it every time. But it happens daily, sometimes more. I need a fix.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
need help será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 194
