Region code incorrect message
I changed the driver in my PlayStation 3 now every time I put a movie in I get this message that says region code is incorrect what do I do
Esta é uma boa pergunta?
It can be a different default region code of the driver which is not compatible with the movies. You should be able to change the region code of the drive for up to 5 times. So change the region of the driver to your place. If you can’t, you can also change the region of the DVDs. Here is the complete guide, check more details
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 193
i think it has to do with the Blis vs Bles thing if you used a driver containing a file with one of these you might have to replace it with one of the other kink.
por waagosh3
