Ir para o conteúdo principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Perguntas Visualizar todos
What is causing a blue tint on half the screen?
My 23" Cinema Display is tinted blue on the right-hand side of the screen. Is this a symptom of a bad cable or inverter board? I don't know all the inner workings of displays, so I'm trying to determine if it's worth trying to repair by replacing a part or just pitching it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Have you try using the calibrator display assistant?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
C Griffith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,497
