Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
Pergunta encerrada
Power wont turn Back on.
Yesterday my power went out so my Imac must of been on so i tried to turn it on later thru out the day it wont turn on! Looked up some Details i can try so it would turn on Like Reseting the SMC that did't also Removed the RAMS that also did't work. so all there is left is if i need a new Power Supply or the Logic BOARD probably went bad well i hope not. i hear a noise on left top Front side AND on the right top back side but you have to put your Ear close to it. What does that mean? PLEASE HELP. i hope is just that i need a new {power Supply}. Oh and the noise only comes on when i plug it on (well Duh).
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Remove the frame and observe the diagnostic lights to the right of the RAM slots and tell us what you see when you try to turn it on. Here;s how: iMac Intel 20" EMC 2133 and 2210 Front Bezel Replacement
Esta resposta foi útil?
Pontuação 2
1 comentário:
Okay i got it to turn On again but Now the Is just VERY loud it sounds like its the FANS or it might be the Hard drive. How can i fix this?
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 88
