Ir para o conteúdo principal
Error 53 + Error 6 During Update
I have an IPhone 6 and it was dropped and cracked, the glass shattered around the home button and eventually fell out, Leaving the homebutton only hanging on by the ribbon. I was pulling my home button out of my pocket one time and the home button ripped off the cable and was gone forever. It worked but when IOS9 came out i tried to update it and received error 53 . Is there any fix? I tried reseting i and got error 6 i think. I've read around and heared its touch ID but i don't know of any fixes.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Not possible to fix whatsoever unless you send it in to Apple.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Maybe not even then
por
I just had my first run in with this error 53. We completed the screen repair a few months ago and he has had no issues with the device since then until the update to 9.1. We tried a few things first like DFU and recovery and RECBoot.
Here is what fixed it for me: We clipped in a new home button flex cable with the original home button and the replacement screen. We did the restore again and it worked! Took out the home button flex cable from back plate and reinstalled the screen and it is problem solved.
Hope this helps you too.
Brian
por
Chai, question for you. iPhone 6 broken screen and missing home button. Phones logicboard is wiped clean and ready to use and unlocked for any carrier it just needs a screen replacement to turn on. How do I go about fixing this phone and avoiding that error 53?
Pontuação 0
2 comentários:
Don't update to new iOS. That's how people get into these situations
por
So just put the entire phone together. New home button new ribbon cable that connects the home button. Turn on phone and all should be fine? As long as I don't restore the iPhone after I turn it on. Thanks.
por
Brian
Pontuação 0
Adicionar a sua resposta
brazins será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 284
