not properley agataing while washing
bottom agatater works but upper does not
Esta é uma boa pergunta?
Upper Agitator
How it Works:
The upper agitator might be damaged or stripped out at the lower agitator connection point. Inspect the agitator for damage or wear around the connection point.
Agitator Assembly
To see parts for your washing machine, you need to enter your model number on the right. The system will then display parts that are associated with your washing machine.
How it Works:
The agitator might be damaged or stripped away where it connects to the drive system inside. To determine if the agitator is stripped inside remove it from the washer and inspect for damage or wear.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 303
