Ir para o conteúdo principal
The HP Pavilion dv9000 series was introduced in 2006.
51 Perguntas Visualizar todos
lost internet connection on my pavilion
My Hp Pavilion has a wireless connection while working on the computer using the internet I lose internet connection in a matter of minutes. Can anyone help figure out why my internet won't stay connected. I go to connections on my computer it says that I am still connected but when I turn off my computer to start again then I can't get reconnected... Help has anyone had this problem?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
are you also losing your date and time settings?
por
Adicionar um comentário
4 respostas
Solução escolhida
Hi, It sounds like your wireless card is going bad. Can you borrow a external pc card to rule out problems with your motherboard?
Esta resposta foi útil?
Pontuação 2
1 comentário:
These HP's are infamous for failed Wireless cards. A good friend of mine just experienced the same issue. +
por
This could be known issue with the Wi-Fi failure in HP Pavilion dv2000/dv6000/dv9000. Could be related to the motherboard failure.
HP knows about this problem.
Free repair for some out-of-warranty HP Pavilion and Compaq Presario laptops
Pontuação 1
the new environmentaly friendly,leadfree, solder that is being used in these it the major problem here. it has a higher melting point but it is more brittle than the leaded solder. Generally you will lose the wifi first then expirence screen/video problems next. There are three ways to fix it. 1 Reflow the solder 2. replace the motherboard. 3. Reball(replace the solder) the chipsets. method 1. is cheap, but will ultimately fail, 2. is more expensive but refurbed/used/new boards all have the same leadfree solder and 3. Reballing is the best fix but very few people do them. check out http://www.laptopreballing.co.uk for more info. FYI I have no affiliation with them but I have firsthand experience with the repair quality that they provide.
Pontuação 0
Just leaving this here. It will definitely address all your issues.
http://www.nvidiasettlement.com/samplecl...
Pontuação 0
1 comentário:
This only has to do with the GPU problem. Unless it fails you won't get help on this link.
por
Adicionar a sua resposta
Corina será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 3,154
